04 Sportback Suspension Problems...looking for advice.
Old Nov 5, 2006 | 05:01 PM
krustykenevil's Avatar
Default 04 Sportback Suspension Problems...looking for advice.
I'm having a similar problem on my 04 Ralliart Sportback. God awful crunching/grinding noise as the suspension in the front left. Sounds to be more during rebound then the compression phase.
I've had the car in to the dealership twice. The first time of course they couldn't hear anything and just "tightened up everything." In again last week as the problem is progressively getting worse and this time the replaced the bushings. Still no change.
This morning I got to work to see what I could find. I pulled the front left wheel and checked the brake pads to make sure they are secure. Then I noticed a brake line with a wire spring type deal around it that was all rusty. Moving it up and down made a pretty good grinding noise so I lubed it up and that noise is gone.
While under the car I also noticed that much of the undercarriage body work is plastic and fairly loose. Not sure if that may be part of the problem but there are several places where the plastic could be slapping up into other parts.
Into the engine bay next to see if anything was loose in there. The airfilter box was very loose. The two clips on top don't seem to be the correct size. So I bent them so they were tighter and shoved a couple pieces of thick rubber under them for a tigher fit.
The last thing I did was wedge some thin rubber into the Mitsubishi caps in the center of every wheel because those were loose enough to rattle as well.
Now the test drive. The car sounds much better now. Most of the residual rattling is gone but there is still the major crunching/grinding noise. It doesn't seem to be as severe, but I only drove it for about 5 miles.
Any other suggestions? Similar experiences? This noise is driving me crazy!!!
Patrick
24
Apr 18, 2020 06:55 AM
pwrhouss
Aug 9, 2019 02:50 PM
jamez667
Nov 23, 2013 02:55 PM
Jamieb2011
Dec 18, 2012 02:25 PM
krustykenevil
Nov 10, 2006 02:23 PM
