2011 Lancer Stalling and Idle Issues
Old Feb 21, 2021 | 10:56 PM
1967 Camaro's Avatar
Default 2011 Lancer Stalling and Idle Issues
Coding on the camshafts advanced too far issue P0011 and P0014. Pulled both oil valve control solenoids, cleaned, checked resistance of coils (7.5 ohms), fired valves with 12 volts and checked voltage signal to valves, all good. Valves were pretty dirty so after cleaning I did change the oil and filter. Also cleaned the dirty throttle body without removing it. Didn't want to mess with the coolant lines. The result is the car runs much better, no stalling, idle is good, no "check engine" messages. When I run the code reader though, it still shows the two codes even after erasing them. Will the codes eventually go away or are they stored forever?
Old Feb 22, 2021 | 12:18 AM
DibbyDibbyDJ's Avatar
Has it missed some oil changes? These engines can stretch their timing chains with poor servicing, causing camshaft timing codes.
If faults come back after erasing then they are still active, and will keep coming back on
Matthew Williams
Dec 14, 2016 03:18 PM
mda185
Oct 15, 2013 11:45 AM
turbovolkswagen
May 3, 2012 06:43 PM
laboh
Feb 9, 2009 09:14 PM
naruto454
May 24, 2007 05:22 PM
