About my 2008 Lancer
congrats wanapasaki on the new car. ive had mine for a year now and no real problems so congrats and enjoy
hey jam just to let you know the pull to the left has been a common issue with almost all gts versions. if you go to http://www.lancerforums.comtheres a thread in there with all the tsb's and common known issues with the lancer. for those of you who hasn't had a chance to go to those forums you should check it out. theres a lot of info in there thats good to know bout 08+ models plus theres links to sites and theres reps from roadracemotorsports and works on there with constant updates on new parts for our lancers. so go check it out
as to lightbulbs you can change to the ultra whites just make sure you dont get bulbs the run at wattage higher than 55. if they are they tend to start melting the harness and start to short. best bet if you wanna spend the money you cana get an hid kit. drl feature can be turned off by dealers(or so ive heard havent checked cause i like the drls. but that means i keep lights on 24/7 as drl wont feed enough volts to run drl) i also will be working on a fix for the drls this sunday so hopefully i can get it done with it working fine so everyone can have hids with their drls working fine.
micowave
Jun 10, 2007 03:34 AM
Manybrews
Apr 12, 2007 04:28 PM
