Intake Help!!!!!
Old Jul 13, 2005 | 05:36 AM
nawgee's Avatar
Default Intake Help!!!!!
can someone help me with my embarrassing problem?
i jes bought a bomz short ram intake off of ebay and im confused as hell!
i know an air intake is probably one of the easiest upgrades to do yourself, but im still confused!
if someone could please help me with the installation i would very much be happy!
by the way i drive an 03 Lancer ES
Old Jul 13, 2005 | 10:13 AM
Default RE: Intake Help!!!!!
Umm what part of this has you confused? It is a real easy install should only take 10-15 Mins. you need a socket wrend(12mm i think? and in some cases a screw driver), just remove all the stock plastic pipeing disconect the mas air meter( unplug it and unbolt it from the stock air box. then install the rubber 90 degree elbow on the throttle body slide the hard pipe into it clap both ends down take the Mas air adapter plate and screw it onto the mas air then take another rubber couplin and slide it onto the end of the hard pipe. then slide the Mas air into the other end of that tighten both clamps down and put the filter on the other end of the Mas air then plug the harness back into the mas aire and thats it
Here is a pic of it installed on a 3G eclipse just copy that it is really easy
[IMG]local://upfiles/3652/2761E4DD16EA4C78A5D036122194C42B.jpg[/IMG]
Old Oct 23, 2005 | 04:26 PM
venum's Avatar
good advice there
Old Oct 24, 2005 | 12:58 PM
wicked_outlander's Avatar
maybe he's confused of which adapter....
apw5060
Sep 23, 2011 08:00 PM
kaiba408
Feb 14, 2007 06:56 PM
kniel023
Dec 28, 2006 12:51 AM
tchun
Mar 30, 2005 03:01 PM
l33tmonkeyman
Jun 5, 2004 01:31 AM
