LANCER???
Old Oct 24, 2005 | 12:53 PM
wicked_outlander's Avatar
Default RE: LANCER???
ORIGINAL: venum
ORIGINAL: Dyno_Man
1st. the only turbo models are the Evo's n they cost about 30k
2nd. Depends wat model ur Lancer is gonna be, ES n regular carry bout 120-30....OZ Rally carry bout 160hp
not true !
the GSR's come turbo > 4G93T
I dunno where you are located, but where I am (Trinidad), the JDM spec Lancers do have this option > the CM5A models
those GSR'S belongs to EVO'S outfit ( here in the u.s. )
Old Oct 24, 2005 | 12:56 PM
ORIGINAL: EMonz57
Here in the states the only turbo model is the EVO. a GSR is an EVO and it has a 4G63. hense where Evolution GSR is all over the EVO world. im not sure if over there it is diff. but I dont think so. either way I havent seen a 4G93 turbo from the factory you might be reffering to the 4G63. What is untrue is the OZ i dont think was 160HP I think only the RA (rally Art) is 160 in 05 models
true...true...OZ rally is only 120 h.p. (my bro. is sportin OZ, and he hates it!!) and RALLIART IS 160 h.p.'s. diffrence?? the MIVEC engine for RALLIART.
Old Oct 24, 2005 | 02:18 PM
Engine Type: 2.0 Liter SOHC inline-4 2.0 Liter SOHC inline-4 2.4 MIVEC SOHC inline-4
Engine Block: Cast Iron Cast Iron Cast Iron
Cylinder Head: Aluminum Aluminum Aluminum
Displacement (cc): 1999 1999 2378
Horsepower @ RPM (BHP): 120@5500 120@5500 162@5750
Torque @ RPM (lbs-ft): 130@4250 130@4250 162@4000
Redline RPM: 6000 6000 6500
Bore x Stroke (mm): 81.5 x
95.8 81.5 x
95.8 87.0 x
100.0
Compression Ratio: 9.5:1 9.5:1 9.5:1
Valvetrain: SOHC, 4-valves per cylinder SOHC, 4-valves per cylinder SOHC, 4-valves per cylinder
Valve Cover: Steel (black) Steel (black) Aluminum (silver)
Electronically-controlled, multi-point injection:
Front-Wheel Drive:
Stainless Steel Exhaust System:
Alternator: 85 Amps 85 Amps 110 Amps
Emissions Rating (Cal/Fed): ULEV/LEV ULEV/LEV ULEV/LEV
ES O•Z®
Rally Ralliart
5-Speed Manual Transmission or:
4-Speed Automatic Transmission with Adaptive Shift Control:
ES O•Z®
Rally Ralliart
Unibody Construction:
Front Independent Suspension with MacPherson Struts and Anti-Sway Bar (mm dia.): 24 24 26
Front Strut Tower Brace:
Rear Independent Multi-Link Suspension with Coil Springs (and Anti-Sway Bar, mm dia.): 13 13 13
Power-Assisted Rack-and-Pinion Steering:
Steering Wheel Turns, Lock-to-Lock: 3.19 3.19 2.86
Turning Circle – Curb to Curb (ft.): 33.5 33.5 37.4
Power-Assisted Brakes: front disc
rear drum front disc
rear disc
Anti-lock Braking System (ABS) with Electronic Brakeforce Distribution (EBD): Opt. Opt.
ES O•Z®
Rally Ralliart
5M/T City/Highway (mpg/mpg): 28/35 28/35 23/29
4A/T City/Highway (mpg/mpg): 25/31 25/31 22/28
Fuel Tank (gal.): 13.2 13.2 13.2
Recommended Fuel: Regular Unleaded Regular Unleaded Regular Unleaded
**Estimate to be used as a standardized comparison with other vehicles. Your mileage may vary depending on driving style and environmental conditions.
Old Oct 24, 2005 | 07:01 PM
Lil red's Avatar
Thanks wicked that helps but you still have too much time on your hands..
Old Oct 24, 2005 | 07:56 PM
ORIGINAL: Lil red
That takes no time to compare. maybe all of 5 minutes. I did the same thing with the 06GS VS. 06GT eclipse took me no time.
Good info I was to lazy to find and compare this time lol
Old Nov 23, 2005 | 08:54 PM
venum's Avatar
ORIGINAL: wicked_outlander
ORIGINAL: venum
ORIGINAL: Dyno_Man
not true !
Ok guys
I see why you are having this misconception
You all are in the U.S. and only know of the USDM spec Mitsubishis
I know of the Japan (JDM) and Singapore (SDM) spec Mitsubishis
the JDM\SDM lineage of the lancer has several variations that include a GSR model
these are not EVOLUTION GSR
they are LANCER GSR
the evo GSR has the evo engine = 4g63T > 2.0L Turbo
this is an evolution
the lancer GSR is a beefed up lancer and carries the 4g93T engine > 1.8L Turbo
it is a lancer, NOT an EVO
these are lancers that carry a more powerful engine than the traditional sedans
Theyy were prob not sold in the U.S.
but they definately exist
have seen several myself JDM specs
do a google search for the lancer CM5A model
illycut
Nov 27, 2009 01:13 AM
method.
Nov 22, 2006 04:39 PM
