signal lights not works
Old May 4, 2013 | 03:55 AM
EliasCerrud's Avatar
Exclamation signal lights not works
Please anyone, my signal lights and the hazard flasher do not work
I check fuses, everything look ok. i think that problem could be a relay, but I donīt know where is it.
please helpme, where is it or if the hazard flasher button also include a relay.
thkz
Old May 5, 2013 | 12:23 AM
mxmikie's Avatar
so what are you asking ????
Old May 5, 2013 | 12:50 PM
You can check a relay by passing a small amount of current through it.
If you don't have any electrical diagnostic experience, then you should take it to a shop. We can't help you from over here.
Old May 6, 2013 | 03:29 AM
ok, my signal lights donīt work, I check fuses, he only I caīt check is the relay because i donīt know where it is.
my cuestion is, where is that relay, the signal lights relay.
Old May 6, 2013 | 07:03 AM
Jeff Collision's Avatar
It is located behind the plastic kick panel below the steering wheel, above the pedals.
Old May 7, 2013 | 12:56 AM
ok. let me try one by one of those relay to get the broken one...
tkz
ehsanabria
Sep 22, 2022 06:22 PM
Raider
Feb 24, 2015 02:38 PM
shownuff80
May 12, 2014 06:21 PM
Maljisto
May 28, 2011 02:57 PM
salis
Oct 22, 2008 05:04 AM
