Tire Pressure
Old Mar 26, 2008 | 07:06 AM
Unicorn's Avatar
Default Tire Pressure
Hi.
I just got a new set of rims and tires for my car, Im using Yokohama SDrive 205/55/16 on 16" rims. What is the ideal tire pressure i should maintain for every day use.
Cheers!!!
Old Aug 15, 2008 | 08:51 PM
quan_vuong's Avatar
Default RE: Tire Pressure
it's available at Advance Auto Parts for around $39.00
Old Aug 16, 2008 | 09:15 AM
andry's Avatar
31 Front and 29 Rear.
Old Aug 16, 2008 | 09:54 AM
07outty's Avatar
optimal tire pressure varies fom tire to tire, car to car , and driver to driver.
there is a way to "read" your tire to get the best contact patch without feathering the edges of your tires.
basically , start with a high pressure ,close to max rated.
look at your tires after driving several miles to see how much of the tire is contacting the road.
let out some air (in 2 psi increments) until you can tell that just the tread suirface is contacting the road.
you do not want to see any wear on the far outside edges.
what ever the pessures end up at is what the correct tire pressure for YOUR tire , YOUR car and Your driving style.
outiehere
Oct 18, 2007 10:36 AM
GITRDUN
Oct 17, 2007 05:00 PM
benchman
13
Sep 10, 2007 12:21 AM
GTAlander
Aug 24, 2005 12:15 PM
Maximus99
May 17, 2005 06:14 AM
