Intermittant Check Engine Light Problem
Old Nov 12, 2013 | 05:57 PM
jssjr5591's Avatar
Default Intermittant Check Engine Light Problem
Just bought a 1997 Mirage LS 1.8L. At speed there is a noticeable hesitation and clicking noise from glove box. Doesn't happen all the time and usually it's about four times. The Check Engine Light comes on briefly each time. Any ideas? Thinking it could be a cam sensor, EGR problem or computer is bad. Thanks for any help. It's got 135,000 miles. Everything else seems good except for this problem.
Old Nov 13, 2013 | 07:42 PM
mxmikie's Avatar
clean your battery cables
Old Nov 14, 2013 | 05:53 AM
jssjr5591's Avatar
Thanks MX. I'll try that-would be an easy fix to
Old Dec 1, 2013 | 01:45 PM
autoexpert2's Avatar
Hi,
Try scanning trouble codes with obd scanner.
And then check engine code
Old Dec 19, 2013 | 07:52 AM
jssjr5591's Avatar
Default Update
Just took car to Battery Mart...local guys that are great...had them check battery. Iy was good and charging system was working fine. Noticed that previous owner had put a screw in positive battery terminal cable end. I had to really tighten ends down to get it to shop. They replaced some worn out and corroded cable ends - original ends had a two-piece metal setup - that they replaced. Cost of repair was $8.37. So far - so good. Haven't noticed other problem - guys said I need to run car more often = I let it sit about 3 weeks without starting. Thanks MX.
nesport
17
Mar 15, 2021 01:16 AM
Crashdot
Mar 10, 2011 06:22 PM
black rider
Sep 28, 2009 03:30 AM
pgb205
Jun 4, 2009 10:40 PM
Ancient Mariner
Nov 18, 2005 09:29 PM
