sensors,relays,help
Old Sep 12, 2006 | 08:42 PM
cristalle's Avatar
Default sensors,relays,help
i have a 97 Mitsubishi mirage while changing the o2 sensor ,wires got wiggled and the car now wont run unless the idle is turned all the way up.i now have 3 sensors (intake air temp. sensor,map sensor and coolant temp. sensor)even after replacing them they still read as bad.I replaced the EEC relay .....wasn't that either.....what are the relays for under the dash by the drivers side? any ideas and help would be greatly appreciated
Old Sep 13, 2006 | 04:01 PM
Lil Evo's Avatar
Default RE: sensors,relays,help
Which engine are you running? cuz the 4g15 is much simpler than the 4g93. but i'm not too knowledgable with a lot of the electronics. check out www.mirageforums.net, there's some pretty handy guys and gals on there that i'm sure would be more than happy to help.
lbell101
Mar 18, 2017 02:42 PM
Lovonzo
Sep 1, 2014 08:37 PM
brknhrtdpimp1489
May 10, 2007 10:15 AM
p4c0
Feb 22, 2007 06:36 PM
juve0882
Dec 7, 2006 01:37 AM
