Spark plug replacement and now have a miss at idle
The plugs are inexpensive. Takes all of 10 minutes to replace them. Maybe I'll throw a new set in just in case one has a bad porcelain or something.
Does anyone know if I have to pull the throttle body to get the IAC motor off? If so, i assume there is a gasket of some sort between the throttle body and the plenum.
Well, it is back. Sometimes when I start my car up, sometimes it will stall. The check engine light comes on, but, because of the year, it doesn't store a code. I've heard something in some posts about possibly being a bad idle control motor. I know it is on the throttle body opposite the intake from the TPS. How do I know if this is the problem?
Also- if you haven't had a valve adjustment in a while- your rough idle can be due to that as well.
JJ
2003 montero
Mar 8, 2010 10:51 PM
jrb1and2
Oct 28, 2006 06:05 PM
