01 Montero LTD Need Ext Water Temp Gauge help
Old May 28, 2013 | 01:27 PM
qenex's Avatar
Default 01 Montero LTD Need Ext Water Temp Gauge help
Can someone please recommend an aftermarket water temp guage that works for the 2001 Monetro LTD.
I tried an mechanical gauge which had it's own temp reader probe that only fitted in the second temp unit sender that has two wires. After disconnecting the original it affected the fan speed and rpm so that's no good, but it did read the temp just fine.
I have not tried the smaller one wire sending unit because the supplied probe was too big to fit. I'm assuming an electric gauge might connect directly to that sending unit.
I'm going to try next an electric water gauge but don't know which one. If anyone has one installed, can you please advise the model and some basic install information. Do you connect it directly to the original single wire sending unit or does it come with it's own sending unit? Please advise.
The reason I need the guage is becuase of the ECU cluster that has failed. I'm not looking to repair it because of the cost. An ext gauge will be fine.
Old Jul 4, 2013 | 03:10 PM
jrmdir's Avatar
I know this is an older post but if you're still looking this is a very popular unit. It plugs into the OBDII port and will tell you a lot more than the correct temp.
http://www.ultra-gauge.com/ultragauge/
SpyderMR
Sep 27, 2013 06:24 AM
qenex
Sep 3, 2010 05:15 PM
Rougesvp
Apr 6, 2010 09:38 AM
darknigh7th
Oct 27, 2007 03:07 AM
wolfman
Oct 29, 2004 06:39 PM
