02 montero limited coolant type needed/starting problems
Old Oct 19, 2020 | 10:50 AM
ridinsolo's Avatar
Default 02 montero limited coolant type needed/starting problems
recently came into the possession of an 02 montero limited. I don't have the manual for it and im not sure which coolant it uses. any help would be appreciated, thank you.
also, it has a starting issue im having trouble locating. it'll turn over, but die unless you give it gas. not sure what that's about but any info would be appreciated as well
Old Oct 19, 2020 | 01:31 PM
Regular green coolant 50/50 mix with water. As far as starting issue - sounds like there is some problem with air or fuel supply. You'll have to dig into it a little to figure out why it's doing what you describe
Brewcity1
Aug 6, 2018 06:30 AM
ruski
Dec 30, 2010 05:32 PM
gsnoddy
Mar 27, 2007 10:47 PM
mobetta
Oct 3, 2006 08:46 PM
mattsride
Mar 3, 2006 09:29 AM
