'03 Montero LTD drivers seat
Old Nov 27, 2011 | 08:42 PM
nesport's Avatar
Default '03 Montero LTD drivers seat
Got a strange prob that just started... drivers seat will not go backwards. Every other control on it works including sliding forward, but nothing back. In trying to problem solve it, the seat is now jammed forward too far making it unsafe to drive. I searched for the fuse (there's none listed in the manual for the power seats), because I was hoping a "soft reboot" would fix it, but I can't find the fuse. Any ideas? Could the switch go bad just for the backwards motion? If so, how hard are these to switch out? Thanks. Steve
Old Nov 28, 2011 | 08:28 AM
redturboeclipse's Avatar
you'll have to pull the driver seat out and go from there to disect the problem. motor may be jammed, and/or the switch.
Old Aug 4, 2022 | 06:40 PM
alldt01's Avatar
Default Took seat out, now what
Hi,
having same issue power seat will not go back. I have taken the seat out of the car and have taken the seat cushion out to try to take the switch out but cannot get the switch cover off.
1. How do I get the switch cover off?
2. Can I manually move the seat back?
thanks for any help
Old Sep 28, 2024 | 06:34 PM
Lynnm's Avatar
Default Fues for power seat
does anyone know we're the fuse is for the power seats driver or passenger won't work.
Old Sep 29, 2024 | 09:45 AM
jrmdir's Avatar
I need to go out and check my Gen III to see if it's the same setup, but the #3 post in this thread is my response to the same problem in my Gen II. Maybe it will help?
https://mitsubishiforum.com/forum/mi...se-help-31946/
Old May 17, 2026 | 02:53 AM
smithbrown's Avatar
Got a strange prob that just started... drivers seat will not go backwards. Every other control on it works including sliding forward, but nothing back. In trying to problem solve it, the seat is now jammed forward too far making it unsafe to drive. Just like finding the right Honda Pioneer accessories for a specific fix, tracking down the right solution here takes some digging. I searched for the fuse (there's none listed in the manual for the power seats), because I was hoping a "soft reboot" would fix it, but I can't find the fuse. Any ideas? Could the switch go bad just for the backwards motion? If so, how hard are these to switch out? Thanks. Steve
The switch can definitely go bad for just one direction, each direction has its own contact inside and that is most likely your problem. Very cheap and easy to replace, it either pops out by hand or has one small screw. Also check fuses shared with the cigarette lighter or accessory outlet since it may not be labeled as seat. If the switch does not fix it the rearward motor may have burned out.
Old May 17, 2026 | 09:54 PM
If the seat moves in one direction, but not in the other, then the motor is OK. If it's the switch problem. I doubt you need to take the seat out to get this resolved. As a temporary workaround you just need to figure out how to bypass the switch and reverse polarity to the motor
supermanu_l
Apr 25, 2016 10:04 AM
Karpata
Sep 7, 2014 08:23 PM
rickfrick
Oct 7, 2012 01:11 PM
rickfrick
Jul 8, 2011 11:59 AM
Stonedaily
Nov 4, 2006 04:43 AM
