03 Montero Overheated, Dripping Coolant, cause?
3.8L 6G75 Engine.
I drove it home on a cold night and sat in my driveway a few minutes listening to tunes. I looked down and the temp was high (250F if I remember right). I drove it in the garage and shut it off. There were no visible signs of steaming, smoke, anything.
Next day I took the skid plate and under engine plastic pieces off to see if I could see anything. It looked like coolant fluid dripping down passenger side of the block, not a lot.
I checked fluids and it was low on Oil AND Coolant. I filled radiator up, and added a quart of oil back in. (I did need more than a quart but thats all I had at the time). I drove it easy around the neighborhood, monitoring temp and engine characteristics. Everything seemed normal to me. Idles fine, power seems normal. Engine came up to temp and t-stat seemed to work. Engine temp remained around 190 during driving.
When I got back it still looked like there was fluid dripping down the block from some place that I could not see. I opened the radiator and it was missing a bit of fluid (obviously leaking somewhere). Water hoses are fine.
I think that the overheat was just due to low fluids...but, cause of this being?
What else could cause this?
Oil is dark but not milky. Exhaust does not blow white.
I want to avoid paying for a head gasket job...my plan was to continue looking at engine for obvious sign of leak. Unfortunately I cannot see the water pump without tearing quite a few things out...headers do look "wet" on passenger side.
Are there some tests I can run, or places I can look?
- Oil - typical blow by over time
- Oil - some slow leaks from exhaust manifolds looks like
- Coolant - water pump? Replaced 4 months ago when timing belt was done. Perhaps timing belt is too tight and impeller eventually tweaked?
You can pressure test the cooling system to see if there is a pinhole leak somewhere that allows coolant to seep out.
Test the head gasket for leaks - there are kits out there to check if you have a blown gasket. They are not 100% accurate, but they should work in most cases if you have an issue.
As far as timing belt being too tight - did you properly tensioned the timing belt idler pulley? If so - the belt tension should be within spec. If not, no one can say if its too tight or too loose.
