04 Montero Limited timing belt.
Old Apr 20, 2009 | 04:43 PM
meak's Avatar
Default 04 Montero Limited timing belt.
I'm about to do my first 60k timing belt replacement. Should I do water pump, tensioner and idler in same time or those should be done next time at 120k? Any suggestions?
Thanks
Old Apr 20, 2009 | 05:31 PM
Manybrews's Avatar
replace only the hydraulic tensioner, as its the only part that has occasionally failed.
Chances are you could easily make 120k on that too..
Old Apr 20, 2009 | 05:55 PM
meak's Avatar
Thanks for your response. In that case I understand so water pump and idler should be replaced at 120k.
Also I read on one of the threads that Montero "can't meet new US rollover regulation" as reason why is not importing any more to US? Can you put more light on that issue?
Thanks Meak
Old May 2, 2009 | 09:11 AM
tj90's Avatar
FOrget the rollover issue. Overblown hype.
I replaced all recommended components at 60k. All components could easily go longer than 60k miles. But while you are in there, they are easy to replace. Its just a question on money...
When my monty hits 120k, I probably just replace the belt and take a chance with the water pump... My pump and tensioners looked great at 60k but I threw them out anyway. Kinda a waste of money.,..
Speaking of which, my timing belt at 60k was in excellent shape as well....
Old May 2, 2009 | 05:44 PM
RussellM's Avatar
Former Vendor
Here is a link of all the parts I typically recommend my customers purchasing when doing the timing job. There is a break down of each part below the link. I could do free shipping on something like this too.
LINK
http://www.mitsubishiparts.net/cart/...19022+MD979171
WATER PUMP MD979171
TIMING IDLER PULLEY MD319022
TIMING TENSIONER PULLEY MD140071
TIMING TENSIONER MD362861
TIMING BELT MD358549
judien
Mar 9, 2018 03:41 PM
Z-drive
Feb 3, 2014 11:02 PM
traskrover
Feb 16, 2011 10:39 PM
rjr325
Feb 25, 2009 07:09 PM
8000RPMS
Aug 30, 2007 05:49 AM
