1998 Montero dies when warm
Old Aug 15, 2017 | 11:06 PM
Texasman's Avatar
Default 1998 Montero dies when warm
Hello, My 1998 Montero runs fine cold but has a rough idle then dies when warmed up. what could cause this? Another thing, While driving the montero the Brake, Automatic transmission, and battery lights flash, also causing a loss of power when lit. There are no codes and I've already replace spark plugs, boots, battery, alternator, and most gaskets on the upper engine. Any ideas on what could cause this?
Old Aug 16, 2017 | 07:52 PM
Texasman's Avatar
Is it possible to get vapor lock in this vehicle?
Old Aug 17, 2017 | 12:06 AM
With all the lights flashing, I'd be checking for a bad ground first. Is the engine carburated or fuel injected?
Old Aug 23, 2017 | 01:55 PM
Texasman's Avatar
Fuel injected
Old Aug 23, 2017 | 08:18 PM
Check engine grounds, wiring to the alternator and battery. Check for cracks in the intake manifold - possible vacuum leak.
Old Aug 24, 2017 | 12:12 PM
Texasman's Avatar
I replaced all direct wiring to the alternator, Ill warm her up and spray some starter fluid again and see if there was anything I missed. Thank you!
Old Aug 24, 2017 | 10:30 PM
disconnect and clean all engine grounds as well as the one from battery to body
Old Sep 17, 2017 | 11:40 PM
Josh Canup's Avatar
Default Sefoam
my 1998 3.0L had the same problem I ran seafoam threw the gas, crank case,and vacuum lines and it quit. Good luck
Old Sep 20, 2017 | 01:46 AM
maco35's Avatar
Check the alternator, might be on the way out.
slammedndirty
Jan 11, 2015 02:33 AM
alyster
Sep 19, 2013 04:14 PM
bigjohnok
Apr 12, 2011 05:47 PM
antlip
Apr 9, 2007 11:37 PM
mmafan
Nov 20, 2006 10:31 AM
