1998 Montero HELP Oil in the WATER
Old Feb 7, 2013 | 12:44 PM
markdam's Avatar
Default 1998 Montero HELP Oil in the WATER
ok experts!!! tell me if there is ANY other way for oil to get in the water other than the head gasket? Last night i saw steam comming from the passanger side hood area so i poppped the hood and saw green anti freeze dripping from a small hose onto the exhaust seems like the hose goes to the thermostat housing? so i check the water and yuck reddish brown muck........ but it NEVER got hot........so im wondering is there a breech elsewhere? oil cooler? some other shared area?
Old Feb 7, 2013 | 09:29 PM
markdam's Avatar
anyone?
Old Feb 8, 2013 | 12:15 AM
mxmikie's Avatar
if you have oil in the radiator it could be head gasket or it could be a bad trans cooler leaking into the radiator did you check the motor oil and trans fluid ???? which one was low ??? if it is the head gasket and you have the 3.5 sohc motor you are in luck cause i have a head gasket set for you and how did this happen since you check all your fluids on this 15 year old truck at least once a week when did you change all the fluids last ??? along with a thermostat and hoses ????
Old Feb 8, 2013 | 10:25 AM
markdam's Avatar
Default right
thats what im saying everyhing was ook.... NO headgasket symptoms AT ALL
xcluziveazn
Jun 29, 2014 01:28 AM
markdam
Feb 7, 2013 11:17 AM
Nolah
Jul 19, 2011 04:03 AM
JohnnyK
Jun 2, 2011 01:10 PM
antlip
Jun 11, 2007 10:29 PM
