2000 LS Ignition Problems
Just did my plugs and wires on my ms 2000 also did my valve cover gaskets used NGK iridium plugs and NGK wires everything went smooth car started just fine ran smooth for about 5 minutes then it just died. Now It just cranks over but it won't start checked all connections everything seems to be seated correctly the MAF is plugged in and all vacuum lines are hooked up the strange thing is that the car initially started and ran for 5 min with no hesitation and then it just died and won't turn back on. I also checked for sparks out of the coils and didnt seem to be getting any out of number 1,4,3 and 6. The coil with 2 and 5 has a good spark. I was able to achieve a spark out of the 2 coils that were not working by swapping the connector from the one that works to the other ones that don't. So now here I am stuck dont know where to look next. Any help will be appreciated.
stevez
Dec 23, 2012 02:11 PM
allallyouyou
Feb 12, 2012 11:13 PM
keithm
Jan 31, 2012 03:33 PM
