2001 Mon Sport Egr check eng light still comes on
Old Jul 2, 2018 | 09:34 AM
Chaphall's Avatar
Default 2001 Mon Sport Egr check eng light still comes on
Replaced valve and module... still showing code.... any ideas
Old Jul 2, 2018 | 06:48 PM
Couple of obvious things to check:
1. condition of all vacuum tubing around the EGR solenoid and valve.
2. EGR solenoid itself
3. Is the ERG tube and passage in the manifold clear?
Old Jul 2, 2018 | 08:04 PM
Chaphall's Avatar
Default Did all of that
Yes that goes without saying but I should have said it - talked to a mechanic today who suggested that the code may just be permanently in the log and it will not go away - I have deleted it several more times and so far it has not came back on while driving city/hwy - thanks for responding
Old Jul 3, 2018 | 02:05 AM
Never heard of a code being "permanently in the log". Have you tested your new ERG valve for functionality? Easy test - engine at idle; pull vacuum on the ERG valve; if engine hesitates and/or stalls - the valve is working. If no reaction - you got a defective EGR valve.
Old Jul 24, 2018 | 12:00 PM
craig1's Avatar
Hi, have exact same issue, check engine just came on codes say EGR, I can purchase online solenoid w/valve, where exactly is solenoid located, is it easy to get to , been checking videos and still not sure?? Much appreciate reply, thanks
Old Jul 24, 2018 | 01:33 PM
EGR solenoid is on the back of the intake manifold right next to the throttle body (towards the firewall). Iti kind of a PIA to get to. The best way to get to it seems to be - disconnect all the wire harness connectors in that area, move them out of the way, then remove a metal bracket holding ERG solenoid (held to the manifold by 4 bolts). After that it is a single bolt holding solenoid to the bracket.
Make sure to take pictures and label ALL vacuum hoses there. If you get them connected wrong - it's back to the CEL shining
miamiguy1105
Jun 20, 2012 05:25 PM
rjr234
Aug 18, 2009 12:34 PM
N/Teclipse
Nov 24, 2007 08:54 AM
serenabkhan
Nov 23, 2007 05:44 PM
asphalt_pimp
Oct 17, 2007 10:15 AM
