2001 Montero Limited 3.5 overheat & aluminum on cylinder wall
Old Aug 15, 2011 | 05:44 PM
5280montero's Avatar
Default 2001 Montero Limited 3.5 overheat & aluminum on cylinder wall
Hi guys, I bought an 01 Montero Ltd. with 137,000 miles awhile back, after the last owner overheated the motor. A fairly typical project vehicle, the motor still ran, though it ran rough with little power. There was no water in the oil, or vice-versa, and I’d hoped it didn’t cook that badly. Upon disassembly, there is aluminum buildup on two cylinders, the worst of which is shown here.
I've done several head gasket changes over the years as a hobbyist, and I'm not likely going to attempt to reuse these pistons/rings. But for whatever reason, I hadn’t run across vehicles getting so hot that they start depositing aluminum on the cylinder walls. It is certainly possible to carefully remove the aluminum buildup with muriatic acid and roll the dice to see if rings are broken and/or ring grooves are sloppy. But I was wondering if any experts here know if it is fairly certain I'd have a “smoker” engine if I don’t do a full rebuild. Thanks!
montylimited
20
Feb 26, 2015 09:18 AM
Sebba
Nov 15, 2006 12:19 AM
BrunoBoy650
1st Generation
13
Jul 24, 2006 06:55 PM
tidus10
Jan 25, 2006 11:46 AM
blackdevil55
Nov 11, 2005 02:28 PM
