2001 Montero Ltd Brake pad and rotor replacement
Old Sep 7, 2009 | 11:19 PM
lovinmrv's Avatar
Default 2001 Montero Ltd Brake pad and rotor replacement
I just replaced the front pads and rotors on "Rhino II", my 2001 Monty ltd. It was a snap. Unscrew 2 bolts to remove the caliper, and 2 more to remove the caliper support, pad, clip and shim assembly.
Pls note that I needed to put a length of pipe on my breaker bar to get enough torque on the support assembly bolts. Also, it took a lot of WD-40 and a few well placed blows with a sledge to loosen one of the rotors.
So, other than tight bolts and expected rust, a piece of cake!
I've attached a diagram fyi.
Attached Thumbnails 2001 Montero Ltd Brake pad and rotor replacement-caliper_assembly.jpg
biscuit
Oct 30, 2010 06:47 PM
lovinmrv
Aug 9, 2009 11:18 AM
areyes0108
Apr 25, 2008 11:10 PM
lovinmrv
Mar 8, 2008 06:43 AM
Torque
Jul 31, 2006 02:59 PM
