2001 montero stalls after 10 min. Help!
Old Oct 20, 2014 | 08:27 AM
01monterob's Avatar
Angry 2001 montero stalls after 10 min. Help!
2001 Montero xls (full size 3.5)
I read the post on the forum and still can't fix this devil. The car runs perfect until it gets to regular temp and stalls. It will not start until it is cold again. Here is a list of what I did so far.
New idle air control
Cleaned out the throttle body
New ignition control module
unplugged the battery and let it idle for 10 min and it stalled.
Please help me if you can
Old Oct 20, 2014 | 09:30 PM
Does it throw any codes?
Old Oct 21, 2014 | 09:39 AM
01monterob's Avatar
no codes
It runs perfect for 10 minutes and shuts off.
Old Oct 21, 2014 | 01:25 PM
01monterob's Avatar
does the Montero have a fuel pump relay in the engine bay?
Old Oct 21, 2014 | 02:25 PM
Check the book for location of the relay. I would check the fuel filter and the fuel pump as well.
Old Oct 21, 2014 | 09:04 PM
Just located the diagram for fuel pump relay. It is located under the hood, driver side where the fuse/relay box is located.
Old Oct 22, 2014 | 07:36 AM
01monterob's Avatar
I will look at it today
Old Oct 23, 2014 | 01:10 PM
01monterob's Avatar
Default many relays
The book does list it. Do you know it's location?
Old Oct 23, 2014 | 06:16 PM
PM me your e-mail address. I'll send you the diagram. Can't make it small enough to post on the forum.
Old Oct 25, 2014 | 08:43 AM
01monterob's Avatar
I sent you my email. Do you think it is the fuel pump relay?
