2001montero limited tensioner and valve question
Old Jul 17, 2021 | 10:30 PM
jxbro43's Avatar
Default Youtube link
Hey Dan Phillips, I'm wondering if you can provide the link from the youtube video as I am looking at doing the same repair! Please and thanks!
Old Jul 17, 2021 | 10:34 PM
jxbro43's Avatar
Old Jul 19, 2021 | 08:10 AM
Dan Phillips's Avatar
Here ya go:
Old Jul 19, 2021 | 05:54 PM
jxbro43's Avatar
Thank you sir!
Old Jul 19, 2021 | 05:58 PM
jxbro43's Avatar
informative but also terrible
Old Jul 19, 2021 | 06:33 PM
Why in the world did he disconnect coolant lines? Then run the engine with no coolant. Hard to make a worse decision...
Old Aug 10, 2021 | 07:45 PM
Hi hunter. Can you tell me if my 2000 montero limited has control arms in the rear and if so, why can I not find any replacements online? Also on the front control arms is there a left and right side or are they interchangeable? Do you normally replace the control arms if the ball joint has failed or do people reuse the arm if it seems ok? And if you replace one side, should you do the other side too?
thanx sorry about the questions but I am trying to be armed with lots of info before putting money out to get my Monty some needed repairs. Thank you for any advice.
dan
Old Aug 11, 2021 | 12:03 AM
Dan, does your Montero have a solid rear axle or independent rear suspension? If it's solid axle with a pumpkin differential - you do NOT have rear control arms. If, on the other hand, it is independent suspension (with half axles going from a stationary differential to the rear wheels), then you do have rear control arms. I think those are called trailing arms. My 2001 has those, but I don't know how yours is set up.
Front control arms are Left and Right hand specific and they are not interchangeable. You do not need yo replace control arms if your ball joint is bad. Just replace the ball joint. There are three bolts that hold them to the control arm. Relatively easy job for experienced person. Just be careful of the car being on jack stands as well as spring loaded components.
Old Aug 11, 2021 | 10:13 AM
Was not terrible to me. Was good news
levanixai
Feb 24, 2014 05:54 PM
ntpatel62
11
Dec 13, 2013 10:36 AM
brdland
Feb 26, 2010 02:17 AM
corsair_105
Aug 23, 2009 03:19 PM
2GxFTWxMack
Apr 7, 2008 10:47 AM
