2002 limited rear disc pads
cool, thanks.
I was able to get one of the pins out last night but they are really seized inside the caliper. problem is only one pin on each caliper goes through and can be tapped out. the other pin stops inside the other side of the caliper. I'll get it out somehow.
Yes i've seen that a few times before. Try a dab of pentrating oil where it contacts the caliper then giving the head of the pin a few taps with a hammer. Be sure to damage the pin where it slides through the caliper or you may not be able to use it again. Good luck!
JJ
JJ
AfroGeek
Apr 14, 2015 05:01 PM
knupxfon
Mar 16, 2006 03:46 AM
firerice
Dec 1, 2005 07:13 PM
