2002 limited rear disc pads
Old Apr 3, 2009 | 11:37 PM
ace of spades's Avatar
Default 2002 limited rear disc pads
there seems to be 2 pins holding the pads into the caliper. how do I remove the pads? or does it need to go to the dealership?
thanks in advance
Old Apr 5, 2009 | 12:14 AM
Joel_CA's Avatar
Remove the clips that secure the pins in their position. Then slide the pins out from the caliper to free the pads.
JJ
Old Apr 5, 2009 | 10:38 AM
cool, thanks.
I was able to get one of the pins out last night but they are really seized inside the caliper. problem is only one pin on each caliper goes through and can be tapped out. the other pin stops inside the other side of the caliper. I'll get it out somehow.
Old Apr 5, 2009 | 03:35 PM
Joel_CA's Avatar
Yes i've seen that a few times before. Try a dab of pentrating oil where it contacts the caliper then giving the head of the pin a few taps with a hammer. Be sure to damage the pin where it slides through the caliper or you may not be able to use it again. Good luck!
JJ
AfroGeek
Apr 14, 2015 05:01 PM
07outty
Jan 8, 2008 10:09 AM
Yamama
Dec 1, 2006 12:03 PM
knupxfon
Mar 16, 2006 03:46 AM
firerice
Dec 1, 2005 07:13 PM
