2002 montaro 4WD does not work
Old Dec 9, 2005 | 11:48 PM
Oldhat's Avatar
Default 2002 montaro 4WD does not work
We had our first snow of the year here in Kansas and the 4WD on our 2002 Montaro would not work. No dash lights would come on.
Stoped by the dealer and talked to the mechanic. He said to shift in and out of 4WD till your arm was sore then do it some more. There is a switch on top of the transfer case , and if you go a long time without using 4WD the elect. contacts stop working. He said he had 2 other Montaro in the shop with the same problem. To change this switch you must drop the trans & transfer to get to it, app. $500.00 So I shifted the transfer alot and it worked. Has any one else had this problem.
Old Dec 10, 2005 | 01:08 AM
Joel_CA's Avatar
Default RE: 2002 montaro 4WD does not work
VERY VERY common problem cause by the inactivity of the switches inside the transfer case or front differential. Click on my signiture to hyperlink to a Montero Sport forum. From there, you can read my FAQ section and read more about it. Good Luck!
Joel, CA
Old Dec 18, 2005 | 11:09 AM
Oldhat's Avatar
Thanks for the reply Joel.
We had another snow this week end and the 4WD worked great. I will not go 8 or 9 months without using the 4WD again.
Oldhat
seehow
May 12, 2015 05:08 PM
salsomano1a
Apr 8, 2012 06:24 PM
Dsmoovy
Nov 21, 2011 03:00 PM
dallas11
Jan 20, 2011 10:23 PM
Skiddy
Nov 5, 2009 09:58 PM
