2002 Monter0 3.5 O2 sensors
Old Apr 3, 2015 | 10:43 AM
Coops217's Avatar
Default 2002 Monter0 3.5 O2 sensors
I bought a repair manual that doesn't really help me. Does anyone know where I can find a diagram for all 4 of these 02 sensors?
Thanks!
Old Apr 6, 2015 | 07:03 AM
SpyVito's Avatar
Default O2
I just replaced all 4. I had one bad and since it would not come out (hex rounded off) I had to remove the "y" pipe that goes from the left and right manifolds to the tail pipe.
Jack up the front of the car and safely put it on jack stands. Remove the skid plates. Look up. You will see the 4 O2 sensors, two on the left bank of exhaust, two on the right. Go to autozone or Napa or someplace and get an O2 sensor wrench/socket and try to budge them--you may get lucky. If not, take the y pipe out and remove them. When you reinstall, use anti seize on the threads and torque to 30-35 ft lbs.
If you shop wisely online you can get all 4 sensors for $100. I only needed one but replaced them all since I was under there anyway.
Old Apr 6, 2015 | 10:47 AM
Make sure you use copper colored anti seize. It is designed for high temperatures. Most O2 sensors come with a little packet of it in the box. Also, take care to only put it on the treads and not get it on the business end of the sensor.
pc
Oct 8, 2015 03:31 PM
nebage
Apr 16, 2013 02:17 PM
gstTurbo2011
May 8, 2006 10:10 AM
dbarker
Sep 19, 2005 11:00 AM
perna00
Aug 29, 2004 09:38 PM
