2002 Montero Limited RV Meter blank / black
Old Apr 30, 2012 | 11:55 PM
cfrench0817's Avatar
Default 2002 Montero Limited RV Meter blank / black
Okay, looking for some help on here. I have been scouring the web looking for a fix but am just not seeing it. Even looking at the Pajero forums I have not found much except to just get a replacement. I am hoping that there is an electrical problem somewhere that is fixable without having to spend too much.
I bought a 2002 Montero Limited secondhand and have begun working to fix all of the issues on it. I have gotten stuck against the darn RV meter. I would really love to have the compass, clock, temperature, and computer info to show up on the display but it is just a blank screen. I looked through forums for a fuse issue but I don't even think the thing has a fuse. Regardless, I tested all of the fuses and they are good. There are some missing from the fuse box but I assume those are not supposed to be there. Maybe I am wrong since the lid to the fuse box in the engine compartment is gone (currently on order). I would really prefer not to open the dash and trace cables because I am not that electrically competent.
I am very much hoping that someone has some suggestions! Thanks in advance!
Old May 21, 2012 | 12:43 AM
maco35's Avatar
Check if he light bulb is out, and the fuse for it is the same as the cig. lighter one.
Old Jun 10, 2012 | 08:25 PM
It turned out to be the cig lighter fuse. I knew the fuse was out but didn't care. Nothing I could find turned up that the RV meter was tied to that. Thanks!
armymen
Dec 28, 2012 12:08 PM
MadDad
4th Generation
Nov 2, 2007 10:39 PM
Sleepytime
May 6, 2006 10:30 AM
16psi eclipse
Sep 19, 2005 07:01 PM
eclipse27
Jul 5, 2005 05:07 PM
