Check Engine Codes
Old Feb 27, 2012 | 06:02 PM
Montero2001's Avatar
Default Check Engine Codes
Hello Everyone,
I have a 2001 Montero Sport that has several codes. I need some help on narrowing down what needs to be replaced. The codes are:
P0174 - Bank 2 system too lean
P0154 - Oxygen circuit no activity detected (Bank 1 sensor)
P0421 - Warm up catalyst efficiency bank 1 below threshold
P0401 - Exhaust gas recirculation flow insufficient detected
P1400 - No DTC - None Found
Any help is appreciated.
Thank you!
Old Feb 28, 2012 | 10:14 PM
biggun's Avatar
Have you reset it and verified which codes returned?
Old Mar 1, 2012 | 06:22 PM
I had it checked at a parts store. He thot it might be a converter but wasnt sure. He reset it, on the drive home the light came back on. Checked them again. Same codes.
Old Jun 13, 2012 | 08:39 PM
Jmchavez1986's Avatar
I have a similar problem. I have P0401 and code P0421 pop off and I have swapped out both the egr valve and the egr solenoid. I reset the computer and drove around for 4 days before the check engine can back on. If anyone has any suggestions or solutions please message back.
membreya
Apr 18, 2013 12:50 AM
mygst97
Jun 18, 2012 08:59 PM
Gstfat
Aug 16, 2008 09:30 AM
spyder4g63t
14
Jul 21, 2008 08:12 PM
agallardo
May 4, 2006 12:18 AM
