2002 Montero LTD - 4x4 Bulbs
Old Mar 8, 2010 | 11:43 PM
rameez00724's Avatar
Default 2002 Montero LTD - 4x4 Bulbs
Hello,
I have a 2002 Montero 4x4 LTD (non-sport) and recently I've noticed that one of the rear wheel 4x4 indicators in the speedometers is not lighting up. Usually the rear wheels lights are always on. I actually unscrewed the frame, pulled the speedometer out and swapped the bulbs and it was working fine after that which confirms that light bulbs are not working.
My question is, where can I find those little bulbs to replace? Also my seat-belt bulb is not working. I did see one bulb on the upper center of the speedometer which I believe works alternatively for lights like ABS, seat belt etc.
Can someone please shed some light on this?
Old Mar 9, 2010 | 12:56 PM
redturboeclipse's Avatar
I had a problem with my bulb going out too, I have the same vehicle as you.
I just hit the dash really hard and it came back on hah.
Can you show us pictures of your removal of the dash and picture of the bulb, maybe we can find out what bulb it is to replace.
Was it easy to access the bulbs? I want to change them to nice LEDs
Old Sep 5, 2013 | 10:01 AM
spinalcracker's Avatar
I'm having the same problem.
How do I remove the panels to get to the 4WD indicator lights?
Old Sep 21, 2013 | 11:29 AM
Default Tap gently
I always laugh when my Montero goes into 1WD (one rear light only). I found that gently tapping the wheel indicator gauge works 99% of the time.
Old Sep 23, 2013 | 08:32 PM
Mr. Z.'s Avatar
Here is a mob that can get you any bulb you need.
I think you need a #74 (T5, T1-3/4)...can't quite remember...
autolumination - Google Search
Below is a link to the FSM section that might help...
http://www.pajero4x4.ru/piii/GR00002500-52A.pdf
Good Luck
Old Oct 7, 2013 | 08:59 AM
7-UP BILL's Avatar
I went to the dealer to get bulbs. Part number is MR444536. I bought about 6 of them for a supply.
HiTeckRedneck
Jul 9, 2019 04:30 AM
Dune_Hopper
Jan 10, 2014 09:00 PM
victorjg
Apr 3, 2013 09:13 PM
rigrunner
Jun 13, 2012 10:49 PM
Danthony
Dec 29, 2011 12:10 AM
