2002 Montero Power Antenna
I just found out while I was trying to replace the antenna mast on my Montero that the plastic part on the old antenna is broken off inside the motor. I cannot find a way to get to the motor, is this a major repair? Do you have to take off the fender to repair the motor? Help!!
When I had to replace the antenna mast I was fortunate that the plastic part wasn't stuck in the motor. I simply used a rag and an adjustable wrench, the rag protects the chrome finish.
To get to it requires possible removing the wheel, depending on how skilled and how well you can snake around down there, then removing fender lining.
then a few bolts to loosen the power antenna from the mount..
harder part is removing entire thing (which means the wiring), have to snake it from the interior where its hooked to the stereo panel, which means removing interior panels.
so yea its straight forward but tedious, of course some parts are easier depending on the excessiveness of the job
Greg Yancey
Apr 26, 2013 08:55 PM
redturboeclipse
Oct 26, 2009 10:41 PM
2002, antenna, broken, car, diamante, disassemble, electric, mast, mitsubishi, montero, nut, power, remove, replace, replacement
