2002 montero sport 3.5L engine removal
Old Apr 21, 2018 | 06:20 AM
  #171
larry4406's Avatar
Originally Posted by nipponpajero
larry4406,
Any updates on your #6 cylinder misfire?
No updates on the misfire thus far...
Old Apr 21, 2018 | 02:25 PM
  #172
Originally Posted by jonnshell30
So I got in all of my bearings/rings/gaskets in today! Still cleaning the heads, and am wondering if I should remove the camshaft. This engine spun a #2 bearing, but had no other issues. All compressions were good, and engine was strong. What are your thoughts?
If your engine has spun a bearing it would be a waste of effort to replace top end and not address the camshaft bearing. Pull the crankshaft and at the very least flush out oil passages and put in new bearings all around. This will insure that you will not have to open it up again for many miles.
Old Aug 20, 2018 | 08:55 PM
  #173
nipponpajero's Avatar
Default Torque spec
What is the torque spec on the galley plugs? I looked everywhere but couldn’t find it.
Originally Posted by larry4406
The oil galley plugs are part number MD040338 and have an 8 mm hex. I took one to a hardware store to try to determine the thread size in hopes of getting a cleanup tap. It appears to be 16mm but it would neither thread into the course or the fine gauges. I also checked it against the SAE thread gauges without success.
Fortunately, the new plugs thread into the block fine despite the damage sustained during removal. I will install them with Loctite 271 (red) and liberally seal the threads.
Old Aug 21, 2018 | 04:59 AM
  #174
larry4406's Avatar
Thanks for checking in!
To be honest I think I just liberally coated the plugs with lock tight and then tightened them by feel till they felt firmly seated. From memory the thread form appeared to be some sort of pipe thread..
Old Sep 12, 2018 | 07:06 AM
  #175
newmont's Avatar
Thank you so much this has been very helpful.
Old Sep 13, 2018 | 05:02 AM
  #176
larry4406's Avatar
Glad it helps. When I started this journey I was struggling for information so I decided to document it here.
Old Sep 17, 2018 | 12:06 PM
  #177
Felixcat's Avatar
Default 2001 montero sport
Hey, off topic but I'm wondering if a 2001 Pajero manual is close enough to replace camshaft seals on a montero sport. Same year
Old Sep 17, 2018 | 01:17 PM
  #178
It should be close.
Old Sep 19, 2018 | 07:30 PM
  #179
jonnshell30's Avatar
FINALLY!!!!! My 2002 is running and running well. I do have a P0174 and P0171 codes, and I also have a slight VLA tick. I am going to replace all of the injectors for the codes. I cleaned all of the injectors as well as I thought was necessary, but still have the tick. Gonna replace all of the lifters as well. But I am very pleased with the results. Overall, I am very pleased with my results. Thanks Larry for your tutorial! Without it, I would have been totally in the dark as to what to do.
Old Sep 20, 2018 | 05:41 AM
  #180
larry4406's Avatar
Jonn - I'm glad my engine rebuild thread helped you! You will figure out the codes I'm sure. Start a separate thread and I'm sure Hunter can help you.
