2002 Montero Sport LS Alternator Issue
Old Oct 10, 2016 | 10:36 PM
res6jya6@charter.net's Avatar
Default 2002 Montero Sport LS Alternator Issue
Low and behold, the battery in my Montero Sport LS was dying. Alternator, right?
Replaced the alternator (the old one was CAKED in oil) with a remanufactured Duralast alternator. Put everything back together, turned it on, and I only get three lights on my dash (Batt, ABS, Check Engine). Runs really funny, too. Hard into reverse, barely wants to go forward... Turns out the 100amp alternator fuse link blew. Okay, replaced. The minute the battery was hooked back up, the fuse link blows again.
Could the Duralast alternator/regulator be bad out of box? Or... I noticed there was a lot of oil on the alternator harness clip. Could the clip be shorting out and causing the fuse link to blow? No other fuses are bad, grounds look good. Tomorrow I will be cleaning the clip and grounds.
Old Oct 11, 2016 | 12:51 PM
Both situations are possible. You can't tell which one is responsible for the blown fuse until you test the harness and the alternator. Since this is an aftermarket alternator (even though it is for Montero), it may have a slightly different wiring that is causing the issue. Test, test, test...
holyghostthug
Oct 15, 2022 05:56 PM
montplusrs
Jan 31, 2014 12:45 PM
Ms Bishi
Aug 23, 2010 03:09 PM
pulpfiction2121
Apr 27, 2008 03:41 PM
bedjemp
May 19, 2005 02:02 PM
