2003 montero sport 3.0L po401 EGR
Old Oct 27, 2015 | 10:19 AM
That would do it. Without knowing exactly how the TB is ported, it is hard to tell why it makes a difference, but the hoses have to go to correct ports. Glad you got it figured out.
Old Oct 28, 2015 | 05:50 PM
inbilya's Avatar
I was on my way to the DEQ station , engine light came on . plugged the scanner in and saw four codes PO401 PO421pd PO 133pd PO401pd
Old Oct 29, 2015 | 04:40 PM
inbilya's Avatar
back to the PO401 code. If i disconnect the solenoid valve and apply 12volts from battery , the egr valve opens and the engine dies if idling, at higher rpms does not die. then I check the connector to see how much voltage the computer is sending to the solenoid valve. its 4.6v . If I rev the engine up , it quickly jumps to 10 or 11volts , then back to 4.6v. (in less than half of a second)
Old Oct 29, 2015 | 11:41 PM
That is proper operation. The solenoid is not actually open all the time. It is constantly being switched On/Off. The frequency of On/Off switching regulates how much the EGR is open. The voltage is fluctuating between 0v and 12v. Regular voltmeters can't measure this fast enough, so they average the values. If you were to hook up a scope to the solenoid, you'd see the change in frequency of switching.
Old Aug 30, 2017 | 07:45 AM
hhughes0320's Avatar
Hello all,
I have a Montero xls 2002 and it was throwing two codes at us.
Po161 which pointed to O2 sensor an bank2 sensor2.
also PO401-which points to Exhaust gas re-circulation flow insufficient.
I replaced the ERG valve, from O'reilly autoparts cost about 110.00.
I did not replace the O2 sensor and it seems to have resolved this issue and the idiot check engine light.
ninjaloops916
Mar 10, 2014 09:01 PM
Daks
Mar 16, 2012 02:51 AM
fguilarte
Oct 29, 2006 01:10 AM
Tractor77
Jun 14, 2006 03:20 AM
jpardinas
Oct 19, 2005 11:30 AM
