2003 Montero XLS transmission fix
Old Jan 27, 2021 | 09:30 AM
Originally Posted by Fekey123
thanks...i understand that but after driving and in the operating temp of atf, the level is way below cold level almost no fluid...really puzzling to me.
Drive. Warm up fluid. Then add 1/2-3/4 quarts to get it up where it needs to be. Transmission dipstick are marked at 1/2 quart between low and high marks.
Drive again. Re-check level. If you get it up to proper level, leave it there. In the next few drives check to see if you're loosing (leaking) fluid anywhere. I'd recommend that you top off transmisdion fluid ASAP. Having low levels is one of the primary causes for wrecking transmissions.
Old Jan 27, 2021 | 09:36 AM
Fekey123's Avatar
thanks again.. will do just that
SERPENTOR
Apr 10, 2019 10:24 AM
navidbe
Jan 29, 2014 09:56 PM
bender031177
Apr 9, 2012 06:05 PM
triestino
Dec 12, 2008 02:32 PM
clipper965
Oct 30, 2008 03:44 PM
