90 Montero start problems
I am stumped... my Montero is a 90 LS and I am having a unique starting issue. First, a little backstory:
the vehicle had set for over a year. Getting it running involved a new starter, fuel filter, injectors, valve cover gaskets, plugs, wires, cap, rotor, thermostat, hoses, and vacuum lines. Prior to sitting it had a new fuel pump, ignition coil, and computer brain. Also other parts too but that’s it related to ignition and fuel systems. Once running, everything seemed fine for almost two weeks and over 100 miles. Until the other day I started at my home drove to gas station, filled the tank (first time completely filling since getting running) and when I got in it wouldn’t start. It turned but wouldn’t fire. So now, it will start when it’s cold or been sitting. It will also start if I turn it off and start it back up right away. However, if it sits for a few minutes, then it won’t start again until it has sat for 20 minutes or so. Since the problem started I replaced the engine coolant sensor per a post on this forum and thought it was fixed but alas it wasn’t. Today I checked that I didn’t have a ground issue and didn’t seem to. I also checked all the hoses in my evaporations system and didn’t find any blockages. I am running out of ideas here.
thanks in advance for any ideas on what to check.
Hopefully today I will get to testing at least the spark. I guess it’s possible there is damage to the optics in the distributor That may cause it not spark when engine is hot? I will have to research testing fuel pressure, if I can do that without the tool or if I can borrow one.
Any ideas why either of those would work fine at cold start ups and driving conditions, then fail after engine is off just a few minutes?
Who knows... Many electrical issue do happen when engine ether cold or hot. Example: cold engine - wires make proper connection, engine starts and runs. Engine warms up, wire heats up, tab bends out of contact - no restart...
wilde
11-27-2017 08:35 PM
mysticrythms
03-19-2014 08:17 PM
p4c0
02-22-2007 06:36 PM
