91' Montero LS Stalled While Braking
Old Nov 27, 2017 | 09:44 PM
Mitsy91's Avatar
Default 91' Montero LS Stalled While Braking
On my way in to work tonight, the Monty stalled while braking at a red light. I started her up and drove on, until the next red, and she stalled again.
Not a rough stall, more like a, I'm going to sleep now, stall.
I sat at the red light and revved until it was green and drove on. Came to a few more stops and no issues. Braked, no stalling. Got to work and drove the lot, braking and going. No issues.
I'm not overly concerned at this point, unless it acts up some more.
Just looking for info on where to start looking.
Thanks
Old Nov 28, 2017 | 12:07 PM
Check if any spark plug wires are loose. It can be a bad connector on a MAF sensor, or a big vacuum leak somewhere in the intake. With engine idling (if you're able to keep it idling) move things around under the hood and listen for a whistle of extra air getting into the intake. You can use a can of starter fluid or WD-40 to spray small amounts of it around various spots to see if you notice change in engine RPM. This helps locating vacuum leaks.
Old Dec 10, 2017 | 05:18 PM
Mitsy91's Avatar
Thanks Hunter, I appreciate the reply.
I did a bit of looking underneath and couldn't find anything out of order. It's also not happened again since. I'm not sure how consistent the symptoms would be for a vacuum leak.
marybethll
Jun 26, 2021 11:32 PM
jimmy42010
Nov 2, 2011 10:02 PM
Electech1
Nov 3, 2006 10:29 PM
glttrybuttrfly
Aug 18, 2005 11:18 AM
95EclipGS
Aug 9, 2005 09:24 PM
