94 Montero 3.0 - vibration
I have a 94 Montero. I was checking to see if the 4wheel drive was operational and since then I have a vibration when going speeds of 50 - 60 mph. The vibration stops after I go over 60 mph. The steering wheel or car does not shake, I only have the vibration. I am a single mom with 3 school aged kids, any advise would be appreciated! Thanks!
Nope! Keep in mind that I could still be wrong. The driveshaft is usually held in with 4 bolts at either end, and should slide out. If you have a mechanically inclined friend that you can bribe, utilize that. See if they can confirm my suspicions.
You cannot tell a driveshaft is out of balance just by looking at it, but you should be able to move it around some if the bearing failed. A driveshaft shop should be able to check its balance fairly easily. It could also be a U-Joint on the driveshaft too.
Does the vibration continue after you disengage 4WD?
Just so you know, those hole in the wall shops are a thousand times better than the commercially owned rip off joints. After they diagnose the vehicle, go get a second opinion too. I would take it into one of those places that offers free diagnosis, and see what they say. Be weary if they start guessing...
Thanks again Sebba. I really appreciate all your great advise & suggestions. I hope you're right and it won't cost me "an arm & leg"! I hope I can find someone in my area who will be able to fix it. I live in Hilo, HI and I can't even get Mitsubishi parts here. I always have to order online. When I previously had a problem with my Montero, 3 mechanics told me they won't touch this kind of vehicle. Thanks again!
You are so welcome, I appreciate your thanks. That's what we're here for.
Wow, that would infuriate me!
If it turns out you need a part, RockAuto usually has everything you need. If not, I may be able to source it locally here. If you covered parts cost and shipping I'd send it to you myself.
antmag33
28
Jul 28, 2017 09:16 AM
tackett1123
Jan 2, 2010 01:44 PM
