94 Montero SR sunroof problems
Old Oct 18, 2009 | 05:28 PM
1krazyhunter's Avatar
Default 94 Montero SR sunroof problems
I just bought a 94 Montero SR and the sunroof has issues. For one it only opens a quarter of the way. It also has a bunch of tree debris (leafs and needles) in the tracks. On more thing....it leaks in the front of it. My question is, does it look like I am going to need to tear the headliner and take the sunroof out to clean it so I can find the main problem? And if so, where do I start and how do I go about this project?
Old Oct 18, 2009 | 05:56 PM
redturboeclipse's Avatar
Well you seem to be on the right track with the obvious.
You may want to see if doing the easy stuff first cures the problem.
So clear out the debris.
Relube the tracks if necessary. And weather stripping may need to be replaced. I would say removing the headliner is not necessary unless you have determined the motor or more internal issues need to be looked into which would require you to.
maq diesel
May 18, 2014 05:50 PM
jthorn75
Jun 4, 2012 04:18 PM
jp2000
Jan 1, 2012 05:21 PM
kuyaz
Mar 9, 2008 04:14 PM
MrJayDeeOne
Aug 23, 2007 03:58 AM
