'95 coolant leak advice needed
Old Nov 24, 2006 | 04:53 PM
ron's Avatar
ron
Default '95 coolant leak advice needed
Hi folks,
I have the 95 Montero with the 3.5 litre. The coolant path (pipe) looks like it comes out from under the intake manifold in the center of the engine and then turns 90 degrees going down the back of the block. BArely visible with a flashlight, it appears there is a joint where one coolant pipe fits into another. This joint is between the firewall and block in the center of the engine. I can not get a hand in there very easily but enough to confirm this is the leak point. So...
What is the fix? Pull the whole motor to get to it? Pull the intake and some other parts? Will a radiator leak repair additive like Bartlets work on this joint or will that stuff compromise the whole cooling system since I have 122,000 on this motor (in good shape)?
This leak seems to come and go depending on engine temperature and other factors. Sometimes it is nothing, sometimes a tiny spot, sometimes (like today) the thing drips a drop every couple seconds. It is almost like the joint swells/seals with temperature? Anyway, tired of putting a gallon of fluid in it every couple weeks (never mind the stress on the motor). Thanks for any advice!!
Ron
Old May 2, 2012 | 06:08 AM
mxmikie's Avatar
it could be the fitting for the heater hose in to the water manifold or it could me the weep hole from the back of the water pump both of these will leak water from the back of the block if you remove the intake manifold you will see
ruski
Dec 30, 2010 05:32 PM
eldrm
Aug 21, 2010 07:09 AM
wega
Sep 30, 2007 11:48 PM
JohnOnt
Oct 28, 2006 05:22 AM
novetek
Feb 20, 2006 04:16 PM
