95 Montero LS Rear end noise
Old Aug 3, 2007 | 02:04 PM
dutch8jr's Avatar
Default 95 Montero LS Rear end noise
Where should I start? I have what sounds like a rear end "roar" and/or a bad wheel bearing at highway speeds. Any suggestions as to the cause?
Old Aug 3, 2007 | 10:57 PM
mxmikie's Avatar
Default RE: 95 Montero LS Rear end noise
hows the brakes ???? when was the last time you checked/changed the gear oil ????
Old Aug 12, 2007 | 07:15 PM
dutch8jr's Avatar
Brakes were recently done (pads and rotors replaced - out of spec to turn). The gear oil was replaced about 10k miles ago.
Old Aug 14, 2007 | 09:13 AM
mxmikie's Avatar
hows the tires???????
Old Aug 14, 2007 | 04:52 PM
dutch8jr's Avatar
New all the way around. I am going to get my girlfriend to drive at HWY speeds and climb back in the back to investigate. From the driver's position, it definitely sounds like a loud, wornwheel bearing - or tires on bad pavement - or off road tread on any hard surface. BUT none of these are the cause. What else could it be? I am almost wondering if it isn't my spare tire hanging on the rear gate making racket. I will check that out too . . . tonight hopefully.
Old Aug 15, 2007 | 12:45 PM
carlover626's Avatar
If they are new tires I would have them re-balanced...it is a cheap way to make sure the tires are not the culprit.
I had the dealer put new tires on my 02 when I got it, and it took 2 shops to balance them correctly before I had no steering wobble or road noise.
Coops217
Sep 14, 2014 12:35 PM
shoeboy
May 6, 2013 10:04 PM
dj_jerry_p
Aug 26, 2009 01:01 PM
Subydrift
Mar 10, 2009 09:47 AM
jkrusa
Dec 19, 2004 09:29 AM
