96 Montero LS 3.0 VSS
Old Apr 30, 2019 | 06:16 PM
meclipsegt's Avatar
Default 96 Montero LS 3.0 VSS
The VSS itself works. Speedo works, but ECU doesnt show anything. so, Im looking at the FSM (13A-1076-1) and the VSS plug they show is a 2 wire, but the truck is a 3 wire. So, how do I test the wire for a ground to ECU then? Which wire goes to ECU pin #86 (thats what the FSM says, I hope its correct)? Thanks in advance.
Old May 6, 2019 | 04:49 PM
1960StudebakerHawk's Avatar
What is a VSS?????
Your post is a bit vague.....what is the issue in more detail?
Old May 7, 2019 | 11:23 PM
Vehicle Speed Sensor? Yeah, more details please. You sure you got FSM for the right model/year?
Old Jun 26, 2019 | 09:22 PM
meclipsegt's Avatar
Yes, vehicle speed sensor. And yes, I have a 96 and http://www.mitsubishilinks.com/ has one for a 96. Not sure what else I need to say, I need to troubleshoot the vehicle speed sensor and wiring. Gauge works, but ECU shows 0 for speed all the time. Cant smog it till its fixed.
Old Jun 29, 2021 | 07:16 PM
Monterooooo's Avatar
Did you figure this out? I have the same problem
Laz
Jan 31, 2014 08:54 AM
Galanthighspeeder
Jun 9, 2011 01:28 AM
Galanthighspeeder
Jun 5, 2011 06:30 PM
eugenexyu
Aug 30, 2010 07:52 AM
mitsu02
Apr 28, 2006 11:42 PM
