Advice please kinda urgent
Old Aug 19, 2021 | 03:03 PM
Dan Phillips's Avatar
Default Advice please kinda urgent
So my key is stuck in the ignition cylinder(2001 Mitsubishi montero limited) and I can’t rotate it all the way counter clockwise to remove it. I have power but when I rotate the key forward it is not starting.
three questions:
1 is there ANYTHING that would automatically lock the cylinder or did it just go bad? It’s occasionally given me problems
2 is the car not starting ( no crank dead) at all related to the cylinder? It seems I may have two problems at once. Dead starter? Bad battery? Other issue?
3. . if the ignition cylinder HAS prevented the car from starting, can I remove the cylinder, cut the ignition switch wires and hot wire it? My car is not in a good location and if I could get it home I could work on it with less
Old Aug 19, 2021 | 04:03 PM
DibbyDibbyDJ's Avatar
Is the car in park? Unless it is you may not be able to remove the key. Also it may not start unless it is in park
But if the lock has had problems previously, then its likely its jammed. Try wiggling the steering wheel and the key at the same time
Your car has probably an immobiliser fitted? Hot wiring it will not work
Old Aug 19, 2021 | 08:00 PM
I’m stupid. Car was not in park.duh.thx
MonteroClassic
Jul 18, 2021 08:50 AM
Wade Nighswander
Oct 13, 2019 04:12 PM
latham
May 6, 2016 05:41 PM
BroD
May 7, 2014 10:46 AM
athlete1012
Jun 17, 2009 09:57 PM
