Aisin transmissions and SP-III
Old Feb 23, 2009 | 04:13 AM
Skiddy's Avatar
Question Aisin transmissions and SP-III
I usually stick with Dexron III for my application, using a compatible Motorcraft Mercon V fluid:
I'm due for an ATF change, and I always drain the torque converter whilst I'm at it, so I have 7.2L of fresh fluid in the system. When I went to purchase my gasket set, there was an offer going on with Dia Queen SP-III fluid. I just want to confirm this fluid is compatible with the Aisin unit on my 2000 Pajero/Montero before I make a very costly mistake. The counter guy said this ATF was for the new Lancer, which seemed rather confusing because to the best of my knowledge, the new Lancer comes with a CVT and not an A/T. Thank you.
Old Feb 23, 2009 | 05:22 PM
Manybrews's Avatar
yes, SP3 works fine in the aisin transmissions.
Old Feb 23, 2009 | 05:54 PM
Skiddy's Avatar
Thumbs up
Thanks very much! I'll go ahead and purchase 10 litres, since they're on offer. Takes a bit of extra fluid to flush out the old, so I reckon 10 litres should do the trick.
LoveMyLancer
Mar 1, 2011 05:07 PM
treasguy
Apr 5, 2010 11:15 PM
cougarkid
Nov 10, 2008 05:09 PM
ekliptstudios
Dec 6, 2006 02:14 AM
clipspeed
Nov 2, 2006 05:34 PM
