It all started with a tick...
Old Dec 18, 2023 | 11:01 PM
You said ticking is worse at startup and gets better after engine runs somewhat. To me that sounds like a lifter noise. Have you tried to run a lifter bleed cycle?
Old Dec 19, 2023 | 01:37 AM
edwa8511's Avatar
I reassemble it with all new gaskets. I also checked the vacuum at the plenum, it was low, but within tolerances.
Yes, I did try the lifter cycle that Mitsubishi suggests, many different times. It never helped.
Old Dec 22, 2023 | 02:38 PM
edwa8511's Avatar
The more I thought about the timing, the more I doubted myself. Then I started thinking this could be an easy fix...foolish me...
I pulled off the coved and checked the timing, and everything looked fine. I'm going to have to keep looking.
Here's what the timing marks look like on the crank. The mark is on the back of the gear so it's easy to see with the pulley still in place.
Timing marks on the crank with the pulley in place.
Old Dec 24, 2023 | 12:26 AM
edwa8511's Avatar
I think I’m going to dig into a little more, check out the head(s). If I find something wrong withe the heads (and the pistons look good), I can replace/rebuild them.
Does anyone know if the 3.0 and 3.5 heads are the same.
Any suggestions?
Old Dec 27, 2023 | 06:35 PM
destey1's Avatar
To get the crank pulley off, you put a breaker bar with a pipe braced against the floor and crank it over. I haven't found any other way. Its really tightened tight at the factory because they had an issue with them coming off. Also use the newer revised bolt, and I've read to use a new bolt each time due to stress fatigue.
Old May 15, 2024 | 06:46 PM
edwa8511's Avatar
I've been slow to get back to this - sorry.
I pulled the driver side head and found a couple of the lifters towards the back of the engine were stuck (the side making the noise). I also found that the cam sensor wire was damaged (don't know if it was enough to affect anything). I ordered all new lifters, gaskets, sensors, and a timing belt tensioner. I'll pull the other head and replace them also.
Any suggestions what else I can do while I'm in there?
Any suggestions on priming the lifters? I found in the manual that they should be soaked in diesel... Is this the normal method for these?
Old Aug 1, 2024 | 12:34 PM
edwa8511's Avatar
After reinstalling everything and holding my breath, we started Monty up...and I was not excited about the results. The engine was running really rough. After walking away for a while, thinking it was a total loss, I checked the codes to see if there was anything that might explain things. There was a code for a bad injector circuit on the number 4 injector. I personally don't think just one bad injector would make it run that rough, but I went ahead and started to dig back into it. Maybe I'll find a connector or something that I forgot to attach also... I will hopefully have testing results for the injector/wiring in the next few days.
Has anyone else had issues with the injector wiring, suggestions?
SAU
Aug 15, 2024 11:03 PM
pharpe
Aug 27, 2013 06:43 PM
Obakemono
16
Apr 23, 2010 10:05 PM
Benzeen
Jul 15, 2009 12:39 PM
BlackMurcielago
Feb 26, 2007 08:51 PM
