alternator belt tightening
Old Jul 19, 2006 | 08:06 PM
montysport02's Avatar
Default alternator belt tightening
I am a new montero sport owner and I have found that our '02 alternator belt is loose. How do you tighten it? It looks like there is a belt tensioner but some posts have said that tightening can be tricky. I can't find repair manuals for this model yet. Otherwise my wife loves it and won't let me drive...
Old Jul 20, 2006 | 05:34 PM
Winshawn's Avatar
Default RE: alternator belt tightening
It is not tricky to tighten. However, if it is loose, I would put on a new belt.
Tighten so you have about 1/4" deflection on the belt with medium pressure.
Old Jul 22, 2006 | 12:14 AM
But how do you tighten it?
Old Jan 2, 2007 | 12:30 PM
ultramindbrk's Avatar
Ok ..there should be a bolt right in the center of the pulley..loosen (do not remove)...Then underneath the suv..Lay on your back..and look upunderneathfor a bolt that is connectedto the tensioner pulley you just loosened..Tighten (Turn it clockwise) the belt should tighten..After you get it where you want it, tighten the bolt on thepulley(The thing the belt rides on)that you loosened. hope this makes some kind of sense..
I noticed I am off a little fromwhen this was posted..but hopefully it will help someone else..
blamesociety
Nov 2, 2006 08:45 PM
picaxkillr
Jul 28, 2006 11:47 PM
91hatchlsv
Mar 22, 2006 10:57 AM
bedjemp
May 19, 2005 02:02 PM
funnycat
May 13, 2004 05:11 PM
