Bad Alternator?
Old Aug 7, 2008 | 11:45 PM
Rumplecat's Avatar
Default Bad Alternator?
My 97 Montero has a new problem with at low RPMS and with the headlights on it makes the voltage meter go down below 12 and the A/T, Brake and Check battery light come on. I tried a new battery and it did the same thing so I am guessing the Alternator. Does it have the voltage regulator built into the alt? Thanks in advance.
-James
Old Aug 8, 2008 | 08:46 AM
Joel_CA's Avatar
Default RE: Bad Alternator?
Yes, the regulator is built into the alternator. You should have at least 14v at all times when the engine is running. If not, check the alternator fuse before condemning the alternator.
JJ
Old Sep 3, 2008 | 05:37 PM
GRN98's Avatar
Same thing happened to my '98. Had to have the Alt. rebuilt. After 3 times of R&Rthe rebuild shopFINALLY replaced the 'diode' assembly and all is well. When it got 'hot' after justa few minutes of running, the lights would comeon and you could watch the volt meterstart dropping.
Old Sep 3, 2008 | 06:01 PM
Check the grounds and the alt output.
Old Sep 14, 2008 | 11:16 AM
Rumplecat's Avatar
Well I ended up getting the alt rebuilt and that did the trick. Thanks guys!
Old May 31, 2009 | 02:18 PM
Minoxman's Avatar
Thanks guys for all you're knowledge. I went ahead and pulled the 3 day old OEM alternator and new idler pulley out of the crashed 96. It was a bear to get it out as my son hit the tree on the right front behind the wheel and into the A pillar. It distorted the right inner fender where the air cleaner assembly is bolted on. Everything seems to be "A" OK.
Thanks again, I'm sure I'll have more questions.
galantkid89
Jul 4, 2011 11:24 AM
nawgee
Oct 20, 2008 06:24 AM
desertkitty
May 7, 2007 01:56 PM
agallardo
Oct 1, 2006 02:07 AM
bedjemp
May 19, 2005 02:02 PM
