Bad Rear Catalytic Converter
Old Mar 28, 2017 | 10:49 PM
Juanchos's Avatar
Default Bad Rear Catalytic Converter
I suspect my rear catalytic converter might be bad/clogged, how can I test since it does not have O2 sensors that will read efficiency like the ones in front?
I'm experiencing low MPG and no CEL light!
Old Mar 29, 2017 | 03:23 PM
You can measure temperature of the converter with an infrared thermometer. Temperature on the outgoing side of the cat converter should be much higher (30-100F) than on the side where the exhaust comes into it. Another way to check if you have a clogged converter is to loosen the bolts between the Y-pipe and main rear converter to create a small gap in the exhaust. If the engine runs happier like that - your converter is clogged.
jvmoney
Jul 30, 2022 11:28 AM
wireman1995
Feb 7, 2012 07:14 PM
burnmyeyes
Aug 26, 2006 12:21 PM
ryanp
May 21, 2005 04:42 PM
FatalJRA
Oct 26, 2004 02:46 PM
