Brake help please
Old Jan 3, 2017 | 06:13 PM
MXLS's Avatar
Default Brake help please
My montero xls is having difficulties braking.. I press the brake but it sinks all the way, I benny reading about brake issues but it only talks about accumulater or booster. It says that the brake pedal gets hard but non of that is happening to me, I have to press the brake pedal twice in order to get a good brake other then that it sinks.. can somebody please help out..
Old Jan 3, 2017 | 10:55 PM
Based on the symptoms you describe - first action is to check brake fluid level, replace all fluid and bleed the lines.
Old Jan 7, 2017 | 02:16 AM
sportshot's Avatar
You have air in the brake lines if you need to pump the brakes to get the vehicle to stop. If the fluid level drops below a certain point, each time you apply the brakes you can introduce air into the brake system. Check for leaks at and around the vicinity of the brake reservoir. Inspect the brakes at each wheel to determine if there is brake fluid leaking. If you can't find a leak then a simple fix would be to bleed the brakes to force the air out of the lines. When you remove the air from the brake lines the brake pedal will not push all the way to the floor since air can be compressed and brake fluid can't.
enzo_hashmat2006
Oct 10, 2017 05:46 PM
dukeyjoe
Nov 7, 2012 05:41 PM
Pokerdude
Oct 22, 2007 08:31 PM
reaper13
11
Aug 31, 2007 10:26 AM
ceril
Sep 23, 2006 02:04 PM
