Bulb replacement in Front Combination Lamp
Old Nov 7, 2017 | 04:05 PM
rcan1015's Avatar
Default Bulb replacement in Front Combination Lamp
2005 Montero
As best I can tell, the Montero head light/combination light has 3 separate bulbs--headlamp, turn signal and side marker. When I use my aftermarket remote to lock/unlock just the tail lights flash. Nothing in the front flashes. The head light and turn signals work fine, so I think the side marker bulbs must be the ones that are tied to the remote. How do you replace them? I sure don't see any kind of easy access with the combination light installed and assume I must remove the headlight in order to gain access. Anybody already done this and want to share the process?
Thanks,
Richard
Old Nov 9, 2017 | 01:39 PM
You should be able to reach all the bulbs from inside the engine compartment without having to remove the headlight assembly. It is a tight squeeze between front of the grille and the air filter (and in front of the battery on the other side), but it is totally doable. The bulbs come out with a quarter turn of the the base. If you check the bulbs and they turn out to be OK, then the issue might be with how your aftermarket remote/alarm is wired. Unfortunately there is no consistency in those and depending on how they were installed, they cause more issues then they solve.
rtracing
Nov 27, 2017 12:43 AM
ShortyRider
Jan 9, 2011 09:45 PM
dksnj
Nov 13, 2006 01:06 PM
dksnj
Nov 13, 2006 01:05 PM
ktown
Apr 19, 2006 12:02 AM
